Front caliper rebuild?
Old May 9, 2009 | 07:15 PM
sforb's Avatar
Exclamation Front caliper rebuild?
Is it hard to rebuild a front caliper or should i buy used ones from rover parts, should i do both, I cleaned a lubed the slids on both front beaks and it stll pulls to the right under breaking, the front left caliper had some cracked rubber around the caliper pistons. 1999 D2 116,000 miles
Thank for any input.
Old May 9, 2009 | 09:18 PM
llPANCHOll's Avatar
I got a rebuilt caliper for my 94 for like $64. At OReileys.. Autozone had them for like $70. It is EXACTLY the same as the calipers that are on it... They are rebuilt.. How much are the ones from Rover Parts??
Old May 9, 2009 | 09:35 PM
sforb's Avatar
roverland wants $100.00 plus shipping, Thanks for the info i will go to autozone.
Old May 9, 2009 | 09:38 PM
greg409's Avatar
If the rubber boots are torn, dirt can/will get in around piston and cause corrosion & binding.
If your left boot is torn & piston is binding, truck will pull to the right when braking.
It'll probably take a good mech 1hr to rebuild a caliper. If there's corrosion inside & it can be cleaned add 1/2hr.
Might be less aggravating to install a rebuilt
luck,greg
Old May 10, 2009 | 10:54 AM
If you are mechanical, you should be OK. One thing to consider when rebuilding a front caliper, if you don't rebuild both, it may pull the other direction because of high mileage and wear on the other side.
Old May 10, 2009 | 01:13 PM
llPANCHOll's Avatar
True..
Mine does not pull, then again.. Ive only got 49k on a 15 year old car..
zukijames
Nov 16, 2012 12:13 AM
SolbergFanBoi
Dec 23, 2011 08:57 AM
tnelsonfla
Jan 10, 2011 11:53 AM
Spike555
Jun 21, 2010 07:27 PM
