Front Cover- Going in
Old Feb 15, 2015 | 08:38 PM
abran's Avatar
Default Front Cover- Going in
So, My Dad's car has a leak from the front cover and he wants it fixed.
He just replaced the water pump and the fan clutch.
Just wanted to make sure I am not forgetting anything:
- Water pump gasket
- Front cover gasket
- Timing chain
- Front crank seal
- Oil pump
- Oil filter extension gasket(Not sure of the name)
- Oil pan gasket
Did I miss anything? And no, we don't want to do the bottom end bearings while the oil pan is off.
Thanks.
Old Feb 15, 2015 | 11:00 PM
dusty1's Avatar
maybe a pick up oring
Old Feb 16, 2015 | 12:42 AM
OverRover's Avatar
Old Feb 16, 2015 | 07:26 AM
me6067's Avatar
Don't forget.
oil pickup oring, if your are doing the timing chain (good idea) make sure you also do both timing gears. When you have the front cover off take appart the oil bypass valve and make sure you clean it out but also replace the oring on the end cap.
Old Feb 16, 2015 | 09:27 AM
abran's Avatar
When you say both timing gears, do you mean replace them? I thought they were re usable?
Old Feb 16, 2015 | 10:39 AM
drowssap's Avatar
not even remotely reusable
Q
Old Feb 16, 2015 | 10:51 AM
me6067's Avatar
The timing gears wear in with the chain. Besides they are inexpensive to purchase and you will be removing them anyhow to install the new chain.
Old Feb 16, 2015 | 10:52 AM
abran's Avatar
Thanks, didn't know that.
Old Feb 16, 2015 | 11:09 AM
me6067's Avatar
No problem, that's what these forums are for. Everyone gives and gets help.
Old Apr 16, 2015 | 07:50 AM
WaltNYC's Avatar
Abran, how did you make out with the front cover? I'm likely to be doing mine soon-ish. Any things to know or avoid?
