Front Crank Main Seal
Old Nov 27, 2019 | 11:18 AM
  #21
Sixpack577's Avatar
Originally Posted by Yoops Racing
a buddy of mine has had great success sleeving these - how do I know? I mine is sleeved and has never leaked since! Call RoverLand in Dawsonville Ga
Is he press fitting a sleeve over a groove worn crank snout that has been turned to a smaller outside diameter?
Old Nov 28, 2019 | 06:01 AM
  #22
Extinct's Avatar
There is a product called speedi-sleeve that is a very thin, hard chrome plated sleeve. You can use it with your existing seal. It covers the groove in your existing hub.
Old Nov 28, 2019 | 08:23 AM
  #23
Yoops Racing's Avatar
Default Crank seal fix
I believe that is correct sir it works very well
Old Nov 30, 2019 | 01:45 AM
  #24
The Deputy's Avatar
You do not have to remove starter to lock flywheel from turning, while removing crank bolt. Just remove rubber bell housing plug, access hole for removing flex-plate bolts. Then turn crank until one of the circular holes in the flywheel appear through hole, then slip an extension with a large socket through the hole, until it bottoms against flex plate, then remove crank bolt.
Entire job takes about twenty minutes.
Brian.
dicksoutforharambe
Mar 30, 2017 10:31 AM
Charlie_V
Dec 8, 2015 08:43 AM
My6speedz
May 1, 2014 03:50 PM
Disconeer
Feb 25, 2014 08:42 AM
Silver_Slug
Aug 23, 2010 02:35 PM
