Front drive shaft
Old Aug 18, 2013 | 03:26 PM
Celto 4's Avatar
Default Front drive shaft
Gooday! I have been reading up on driveshafts . My truck has 142,000 on it. I have always monitored my front shaft as my daughters 2000 went. There is a very very small bit of movement otherwise tight... Perhaps replace anyway I'm thinking!
Old Aug 18, 2013 | 03:42 PM
If it doesn't have 1 on each of the 3 front front u-joints, it is an accident waiting to happen.
If you are mechanical you can rebuild them for around $110 or buy one of the newer designed ones for around $350, just do one or the other cause if it fails it will take out the tranny.
Old Aug 18, 2013 | 04:28 PM
Celto 4's Avatar
Thanks Mike will do!! I can do and I have never balanced on other shafts does the Disco require that as a rule?
Old Aug 18, 2013 | 05:06 PM
Send me your e-mail address and I'll send you a PDF file showing all that needs to be done.
Old Aug 18, 2013 | 06:28 PM
Celto 4's Avatar
Hi it's. Landyplace@aol.com. Thanks
Old Aug 18, 2013 | 06:30 PM
Celto 4's Avatar
If I were to buy one what do you suggest?
Old Aug 18, 2013 | 06:59 PM
moorebl's Avatar
disco mike can you send me the PDF too. moorebl@outlook.com
Old Aug 18, 2013 | 08:04 PM
I always recommend either Great Basins Rover or British Parts of Utah.
Old Aug 18, 2013 | 09:02 PM
Fivespddisco's Avatar
Why is that ?
The GBR HD shaft is inferior to the Tom Woods shaft and cost more. They sell a reman shaft for a few dollars less then a new Tom Woods.
British Parts of Utah looks a lot like a tom shaft but I can not tell from the pic.
Old Aug 19, 2013 | 10:24 AM
antichrist's Avatar
The pdf instructions linked to in this thread are more accurate.
https://landroverforums.com/forum/ge...02/#post164811
The last time I looked at the one DM sends out it had incorrect information.
