Front Drive Shaft Care
the zerk (fitting) on the shaft portion doesn't have enough clearance with the cat at articulation.....so it hits. the solution is a allen head grease cap. remove it and put fitting in, grease it and swap back to the cap.
Tatton Shaft Photo by wysvx | Photobucket
This is the drive shaft that I have, and it looks like there is a zerk there... please correct me if i'm wrong
Thanks Dusty for the illustration. I actually have a zerk fitting in that #5 spot. I thought it was just to grease the slip joint... is that the fitting to grease the centering ball?
the centering ball zerk is hardly visible without dropping that end of the shaft, so you can articulate it
