Front drive shaft question?
Old Feb 21, 2009 | 10:50 PM
IDAHODISCO's Avatar
Default Front drive shaft question?
Just picked up a 00 disco 120,000 miles I have a slight vibration on the stering wheele When I decelerate after 50 mph me and Spike 555 both agree I should start with the U-Joint! So I dont know if just replacing the universal part will cure the problem I dont want to spend the money on a rebuild just YET!! But is that what breaks and kills the trans...?
Old Feb 21, 2009 | 10:55 PM
okdiscoguy's Avatar
Yes do it now
Old Feb 21, 2009 | 11:18 PM
malmberg's Avatar
I ordered my parts from rock auto and recieved them within a few days for around $90. Then I took it to a driveline shop, in hand, and spent $65 for the labor. So for around $160 you can get yours done.
Old Feb 21, 2009 | 11:45 PM
IDAHODISCO's Avatar
I was thinking of just showing up are discos universale joints hard to find special size?
Old Feb 22, 2009 | 07:57 AM
You could go to NAPA today and buy the u-jonts.
So yes, LR u-joints are easy to find. They fit more than just LR's.
Old Feb 22, 2009 | 09:04 AM
What is also needed and harder to find is the required centering ball kit, like the Percision 617. If not replaced at the same time, you can be sure of a failure within weeks of the rebuild.
Old Feb 22, 2009 | 09:14 AM
Mike-what are the part numbers for the u-joints themselves?
Old Feb 22, 2009 | 10:20 AM
nynole's Avatar
I posted part #'s and cost on Friday
https://landroverforums.com/forum/sh...ad.php?t=19966
Old Feb 22, 2009 | 07:59 PM
IDAHODISCO's Avatar
Wow thanks for the heads up!
Ok so I will pick up three universale joint's and one centering ball kit!
Mike how $$ much would something like this run at a landrover dealer?
Old Feb 22, 2009 | 08:07 PM
Here you go.
