Front Drive Shaft U-Joints
Old Sep 2, 2007 | 12:28 AM
Dino76's Avatar
Default Front Drive Shaft U-Joints
Just came back from the dealer whereI was told that my front drive shaft is falling a part and needs to be replaced with a new one for $700 plus $200 for labor. Since a drive shaft is just metal and u-joints my thought is to rebuild it myself. I have been able to find one of the U-joints and read on a earlier post to get the lubeable joints. My question is does anyone know what size U-joints I need and where to get them?I have worked on drive shafts before and it has never cost me $700 for one. For that money I should be able to put a rock crawler drive shaft in and never have to worriy about breaking it,
Old Sep 2, 2007 | 01:04 AM
llesra's Avatar
Default RE: Front Drive Shaft U-Joints
you can get the u joints here
http://www.rockauto.com/catalog/rafr...amp;a=FR46-344
Old Sep 2, 2007 | 11:51 AM
Dino76's Avatar
Thanks for the link. I just crawled under my Disco and the drive shaft seams tight to me. I tried moving while in park and had absolultly no movement. My concern is that the shop said front drive shaft but meant from axle.I am getting alot of vibration while over 50MPH. It seams to be coming form the front passenger side. I first thought bad balance on the tire and when in the shop yesterday to have the ABS ECU recall done they tole me that the drive shaft was "Falling out" of the truck and was the cause of the vibration. Any thoughts???
Old Sep 2, 2007 | 03:46 PM
Adz's Avatar
Adz
What year and model of Disco? Disco 1 and my Defender are almost identical under the skin, Disco 2 I know a lot less about.
Front prop shaft UJ's would cause vibration at around that speed - unlikely it would feel like it was from one side or the other.
Could be they mean stub axle? Again, if it's a Disco 2 I'm not sure here but there's no way that's a $700 part for a Disco 1, in fact you could probably buy 10 of them including shipping from the UK for that much if it's a Disco 1.
Old Sep 2, 2007 | 11:14 PM
Dino76's Avatar
99 Disco 2 121K
Old Sep 3, 2007 | 08:28 AM
Seems tight, doesn' cut it when it comes to u-joints. If you don't have grease fittings on those two u-joints in the constant velocity houseing, them replace them or get ready to buy a new tranny which will be the next step when your shaft fails.
Old Sep 3, 2007 | 09:44 AM
Dino76's Avatar
Mike,
I agree, there are grease fittings on the front but not on the back. I have already ordered the new u-joints all around, but I am concerned about the front drive shaft now, because the words "Falling out" from the tech at the dealer. Can you check the front axle by jacking it up and checking for play? Do you have to replace the whole axle or is it usually a bearing like most cars? If so do they have to be pressed out and back in or will a slide hammer do the job?
Old Sep 3, 2007 | 12:02 PM
Call me and in the mean time, I can show you how to drop the drive shaft, engage your CDL and drive on the rear shaft only till the repairs are made.
303-862-7680
Old Sep 5, 2007 | 05:53 AM
jskrebs's Avatar
I am in the same boat with regards to my front shaft. I was wondering,
Do you need any special tools to change out the U joints?
Should the front joint on the rear shaft be changed at the same time?
Jeff Krebs
99 D2 112K
Old Sep 5, 2007 | 07:18 AM
Jeff, How often do you have you drive shafts greased, should be once a year. If they don't get greased often, you may have some warn out u-joints in which case I would replace them as opposed to waiting for them to fail.
If you have never replaced u-joints before, you would need a pair of pliers that are designed to remove the C clips which hold the u-joints in. As for the double pair in the constant velocity joint, you don't want to tackle those if you have never done then before.
U-joints are not expensive, call around to different shops, especially tranny shops and get a quote on replacing them.
