Front end knock
Old Feb 22, 2013 | 02:17 PM
shady milkman's Avatar
Default Front end knock
I installed the TF 3" lift recently and now I have some sort of knock underneath the engine, can't tell if it's the sway bar, springs, shocks, I have no clue. Anyone have any idea where to start? The new rubber is being put on now along with an alignment, I'm hoping they either find something loose or the alignment fixes the issue.... And it only does it turning
Old Feb 22, 2013 | 02:22 PM
ZGPhoto's Avatar
How long have you had the lift on?
Old Feb 22, 2013 | 03:07 PM
Two days, I can't figure it out. Like I said I'm having the alignment done at the moment but for the past two days it just sounds like something loose, almost as if the wheels are tightened down... If that makes any sense
Old Feb 22, 2013 | 03:08 PM
Maybe the coils aren't set in the proper position?
Old Feb 22, 2013 | 03:12 PM
ZGPhoto's Avatar
Have you hammered them in location? if they aren't seated properly(inside the upper retainer) then you can have some annoying sounds...ask me how I know
Old Feb 22, 2013 | 03:21 PM
Guess I'll try that first. I did notice that where the old coil was seated at the top was off a little but it wouldn't fit on the bottom seat any other way.
Old Feb 23, 2013 | 11:10 AM
SuperSport's Avatar
Could it be the Front Driveline tapping something when spinning? Maybe the new angle has moved it too close to something while turning.
Old Feb 23, 2013 | 11:12 AM
May also want to re-torque everything on the front suspension.
coors
Jan 11, 2013 09:28 PM
gtuplin
Jul 15, 2012 12:18 PM
salve7
Jan 7, 2010 02:34 PM
targotsi
Feb 18, 2009 05:58 PM
stick
Jan 27, 2008 01:29 PM
