Front end shake
Front end shake
My 2003 disco ii with 930000 miles is at it again. It did this a while ago then stopped.
When I reach 25mhp, and up to about 45mph, I get this horrible shake in my drivetrain. It does not go away as I go faster but it does smooth out to a steady vibration. If Im in park and rev up the engine it does not do it, but if I am at 40mph and put it in N to coast it will continue. It can be worse on one leg of a trip than another. I just cannot seem to narrow down the location. No signs of cracking on my propshaft, cv boots are all in tact, no visible crack or leakage from the front diff (but ill be opening that up tonight just to be sure). Im at a loss.
Yes it does still have the Rotoflex propshat in it. I check that everytime I crawl underneath it, and as of now no signs of wear.And when I sy vibrationit makes the change in my cupholder jingle.
You think something like them beng out of balance? I have not run over or hit anything. Ill get under it in a few to see if I can find where a weight was lost. It has a mechanical grinding frrl too it though. Im not ruling out your suggestion Ill deff take a look that way. It is still tracking true so they are in alignment. The roads in my area suck though since our highway engineers felt allof our roads needed NASCAR inspired slants for rain drainage.
