Front engine coolant leak...
Old Feb 28, 2013 | 04:47 PM
jrkstore43's Avatar
Default Front engine coolant leak...
Hey gang,
Well, I've got a new issue. Leaking coolant from what appears to be behind the water pump. Not the water pump itself, but what really looks like the timing cover...
It's quite hard to see exactly where it's coming from, but it's definitely a steady trickle when she gets to temperature.
Thoughts?
Thanks.
Old Feb 28, 2013 | 05:14 PM
Pressure test the coolant system and get under the truck with a flash light to find the leak location.
Old Feb 28, 2013 | 11:19 PM
robdis96's Avatar
A pressure test kit can be bought at Harbor freight for around $70 that will fit just about anything and you can do the tool loan at most stores like Advanced, O reillys etc. You pay for the tool and then when you bring it back thy refund you the money so it is of no cost to you.
I just did my front cover, wasn't really that bad/hard. Did timing chain, gears, oil pump and water pump since I had it all apart.
Old Feb 28, 2013 | 11:29 PM
jfall's Avatar
Careful.
Timing cover leaking can get coolant into the oil.
That ruins lower end bearings too.
Old Mar 1, 2013 | 05:43 AM
drowssap's Avatar
timing cover gasket is a common failure
Old Mar 1, 2013 | 07:07 AM
common - see this current thread with pictures and info on scope of work (SOW) -
https://landroverforums.com/forum/di...nt-leak-29492/
Old Mar 1, 2013 | 11:21 AM
jrkstore43's Avatar
OK, so I cleaned a bit underneath the truck and it looks to me like the leak is possibly in two areas: 1) water pump gasket and 2) more prominently, behind the water pump. I have two pictures attached taken from the underneath driver's side vantage point.
Is the more prominent leak at the timing cover gasket from the way it looks?
Thoughts?
Thanks.
Attached Thumbnails Front engine coolant leak...-img_3812.jpg   Front engine coolant leak...-img_3813.jpg
Old Mar 1, 2013 | 11:37 AM
Well, maybe the leak from the WP is being blown by fan back to the other spot. Pressure tester would help.
Old Mar 1, 2013 | 11:48 AM
jrkstore43's Avatar
Thanks. I can actually see the coolant weaping from the area I marked "leak" after the engine is to temperature and then shut off.
Old Mar 1, 2013 | 12:01 PM
The timing cover gasket is then suspect. While you are in there you have some other items that can be attended to.
1. O ring for oil pickup and loctite on bolts that hold it (not the oil pan itself). Clean oil pickup.
2. Oil pump gears.
3. Timing chain inspect / replace.
4. Water pump inspect / replace
Takes some wrench time, but has good rewards. Replace depends on wallet, time available, vs future wallet and future time available. If you were a Washington politician this sort of decision could occupy several months or years.
