Front Fog Light issue
Old Aug 29, 2015 | 10:53 AM
Cbrcrzy's Avatar
3rd Gear
Default Front Fog Light issue
So my drivers side front fog light dosen't seem to want to work. I replaced the bulb, checked the fuse, and looked at the connectors which to my eye seem fine. The passenger side works fine. I am out of ideas any help would be greatly appreciated.
Old Aug 29, 2015 | 12:18 PM
lordmorpheus's Avatar
While it's possible that the new bulb was defective right out of the package, the first thing to do would be to see if you are getting power at the connections. A cheap multimeter can be gotten for about $20 and is a great tool to have. Digital meters are easier to use, but a bit more expensive.
If you aren't getting power power at the connections with the switch on, you will then have to backtrace the wiring, looking for breaks, worn insulation, etc..to where they originate. Once you find where the wires start, you can see if you are getting power there. If not, backtrace further.
abran
Oct 1, 2013 09:09 PM
BlueDiscoII
Jan 8, 2013 07:03 PM
outback96
Jul 5, 2009 07:33 PM
Princess
May 28, 2009 10:47 AM
mhowarth
Dec 31, 2007 03:56 AM
