Front Prop Shaft Bolts
Old Sep 28, 2010 | 12:19 PM
Fireman's Avatar
Default Front Prop Shaft Bolts
After recently removing the front prop shaft on my DII, I was forced to replace the four bolts with grade 8 bolts (same size) due to lack of local availability of the stock bolts. Does anyone know if this is a major issue and whether these need to be changed ASAP?
Old Sep 28, 2010 | 12:24 PM
Bryan H's Avatar
Shouldn't be a problem as long as you used lock-tite.
Old Sep 28, 2010 | 12:39 PM
Fireman's Avatar
No lock-tite, but I did use lock nuts.
Alex_M
Sep 7, 2024 05:21 PM
blcp86
Jul 24, 2009 07:49 AM
jw928
Feb 28, 2009 10:26 PM
tomfraser
Jan 23, 2009 01:59 PM
aaveryy
May 12, 2007 07:51 AM
