Front Prop shaft replacement
Old Jan 30, 2014 | 11:49 AM
xxdoylexx's Avatar
Lucky8 Llc. - Take the road less traveled...
This is the Page for lucky8 drive shaft
Old Jan 30, 2014 | 01:47 PM
hankeester's Avatar
There's the direct link to the propshaft, $218 plus another $20 for shipping.
Old Jan 30, 2014 | 01:59 PM
ZGPhoto's Avatar
^those are both direct links to the shaft
Old Feb 7, 2014 | 10:57 AM
hankeester's Avatar
So Lucky 8 is sold out of them and won't have any in stock for 2-3 weeks. Since mine is chirping I can't afford to wait that long and am not driving it anymore til I get it replaced. I found one on Fleabay for $280 and it's a Proshaft. It says it has 5 grease fittings, dynamically balanced, and also says the constant velocity unit is greasable which I'm assuming is the center hub since they're saying it's right under the cat converters.
This sounds like the next option.
Land Rover Discovery 2 CV Front Drive Shaft 1999 2004 | eBay
Old Feb 7, 2014 | 12:13 PM
dusty1's Avatar
fyi. if you have cdl, you can engage it and remove the bad shaft. you will be cruising 2wd, but you will be cruising.
Old Feb 7, 2014 | 12:18 PM
hankeester's Avatar
I was reading that. Where is the nub I have to turn underneath to do this?
Old Feb 7, 2014 | 12:21 PM
hankeester's Avatar
and can I just have one wheel off the ground to take it out and/or replace? Or does the entire front end need to be up?
Old Feb 7, 2014 | 01:20 PM
dusty1's Avatar
I just put shifter to n and chock
the nipple is on the pas side front top of transfer case
Old Feb 7, 2014 | 04:14 PM
Colorado David's Avatar
Hey. Wait a minute. Your original post says this is an 04. You should have the CDL on the transfer case shifter.
Old Feb 7, 2014 | 04:25 PM
dusty1's Avatar
it is the horizontal motion in your transfer shifter, then......much easier
