front and rear axil oil level
Old 12-05-2008 | 07:43 PM
caleb's Avatar
Default front and rear axil oil level
How do you check front and rear axil oil levelthank you
Old 12-05-2008 | 08:32 PM
Default RE: front and rear axil oil level
There is a plug on TOP of the differential, it will take a 1/2" drive rachet to loosen.
With the truck on level ground remove the FILL plug, stick your finger straight into the hole, if it gets wet, you are fine, if not you need to add gear lube.
Check both diffs the same way.
This is also how you check the transfer case fluid level as well.
Old 12-05-2008 | 09:04 PM
salve7's Avatar
Sounds like sex-ed!
Old 12-05-2008 | 09:12 PM
If your figner ain't wet she ain't ready to be driven.
Old 12-06-2008 | 12:49 AM
Urban Panzer's Avatar
heres a few pictures etc that will help, its for a D2, but exactly the same principles apply
http://www.discovery2.co.uk/diff_oils.html
Old 12-06-2008 | 01:42 PM
JBEGIN's Avatar
Cool, Panzer, Thanks for posting that link, as you know My Rover is a 99 D2, and I suspect i should check my Differentials, have no clue when the last timeThey had been checked. I Think right off the BatI think I'll look into getting that copper plug X 2 and ill be rockin along nicely.!
dpluto21
Freelander
07-17-2010 07:26 PM
mwindth
05-02-2010 03:47 PM
SonicJunior
Defender
09-26-2006 12:31 PM
chrisusvi
02-25-2006 04:19 PM
Quick Reply: front and rear axil oil level
