front right sensor output low
Rave, under brakes, shows the pins that the wheel speed sensors go to at the ecu. I would splice into the wires for both the front wheel speed sensors. If you run a few jumper wires you should have no problem closing the hood and driving the truck. Set the meter to a/c volts and watch the increase in voltage on the good side as you accelerate. Then look at the voltage signal on the bad wheel at your 10mph range when the lights comes on. See if anything is obviously different.
Connector at ecu
C0505
Pin 1
Pin 2
Pin 3
Pin 4
Connector at ecu
C0505
Pin 1
Pin 2
Pin 3
Pin 4
