front rotors questions
Old Oct 6, 2007 | 02:36 PM
loic's Avatar
Default front rotors questions
is the big nut in the midle holding the rotors in place ? if so, what size it is ?
i need to change my rotors.
Old Oct 6, 2007 | 02:46 PM
Landzu's Avatar
Default RE: front rotors questions
I take it that you have a Disco I,, so yes there is a big nut and
you can get the tool from www.atlanticbritish.com
Old Oct 6, 2007 | 02:53 PM
loic's Avatar
no actually it's a DII. but when I removed the wheel ( 6 months ago..) I noticed that big nut that seems to hold the rotors.. but I didn't looked any further..
Old Oct 6, 2007 | 03:36 PM
StevenDiscoII's Avatar
On DII the front brakerotors are held just by the 5 mm (or 6 mm ?) setscew, and arejust sandwitched-in between the hub and the wheel be the wheel lugs.
Old Oct 6, 2007 | 04:24 PM
They are also held on by a large #4 phillips screw that usually needs to be busted loos by a hand held impact driver after applying some penetrating oil.
Old Oct 6, 2007 | 04:48 PM
loic's Avatar
ok, I found and removed the + screw ( what a pain in the neck to remove it !!! ) actually I'll need to buy a new one, the head is pretty messed up.
I'm not sure where are those set screw you are talking about. I didn't see anything else holding the rotors.
but maybe that's why I couldn't get the rotor loose..[&:]....... if there is a trick to it, please share !!
I need to change the rubber seal on the pistons, i'm missing half of one, and the rubber is really dry, from where I could get those ?.
it look like my brake (at least front left) got a little stuck and over heat, as I have a large ( about 1 inch wide) blue strip on the rotor, which indicate exessive heat....
I do all my service on my bike, but I never did anything on the Disco. and I can't afford to bring to dealer for anything right now..
Old Oct 6, 2007 | 05:25 PM
Atlantic British has the caliper seal kits.
Old Oct 6, 2007 | 05:43 PM
loic's Avatar
i'll check them out, thanks !! do you have any trick to get that rotor out ? it is stuck. I even try placing a piece of wood on the rotor and hit it with an harmer, it doesn't move !!
Old Oct 6, 2007 | 08:54 PM
If the caliper has been removed and the phillips screw removed then use a bigger hammer, that is Rover number one tool besides duct tape.
Old Oct 6, 2007 | 09:06 PM
ORIGINAL: Disco Mike
That's what I meant by the Set-Screw [sm=smiley20.gif]
