Front Sag - Shocks?
Old Feb 9, 2010 | 07:08 PM
boxerboy2's Avatar
Default Front Sag - Shocks?
I have a 04 DII with OME heavy duty springs and Procomp 9000 shocks. The front right side is sagging a little (1/2 inch +) and my guy says its a bad shock. I'm clearly confused as I thought that Springs controled ride hight and that the Shocks controled movement with no real load on them.
Comments from the experts please.
Thanks
Old Feb 9, 2010 | 07:27 PM
lipadj46's Avatar
You are correct that the springs support the truck. You installed the correct springs on the correct sides?
Old Feb 10, 2010 | 04:59 AM
humroot's Avatar
Thanks
The OME springs are different heights. The Drivers side spring is a little taller than the passenger to account for your weight. When you installed the springs, did you put the taller one on the drivers side? If yes, it is normal for the drivers side to be a little higher than the passenger side when no one is in the truck.
arnottdoug
Apr 26, 2012 01:39 PM
WindrockRover
May 23, 2011 04:04 PM
salve7
Nov 17, 2009 05:43 PM
rphotographer
Dec 20, 2007 01:03 PM
baysentp
Aug 10, 2007 06:15 PM
