Front Spring Install Question
Old Mar 30, 2008 | 07:52 PM
humroot's Avatar
Default Front Spring Install Question
Hi guys. Getting ready to install some OME 751's in the front and have a quick question. How high does the truck need to be to get the clearance to remove the old and install the new spring? Can I use the bottle jack and then put it on stands? I have a hi-lift, but there is no place on the front of the truck for it. I was looking at floor jacks, but the biggest one only went 20" high.
Also, both the new springs are OME 751's, but one is 3/8" longer than the other. Will this matter after they are installed and under pressure?
Thanks!
Old Mar 31, 2008 | 05:34 AM
antichrist's Avatar
Default RE: Front Spring Install Question
I don't know exactly how high, but you'll want a floor jack anyway to put under the axle to lower/raise it when installing the spring. You can do it with a bottle jack, but I don't consider them safe for such a job and personally wouldn't use one if I had a choice.
Get some good jack stands that reach at least 20" (place them under the frame near where the radius arm attaches) and your floor jack under the axle. That should get you there. Some 4x6 blocks of wood come in handy as well. I keep a good supply of wood in my garage for cribbing.
Old Mar 31, 2008 | 08:21 AM
One of the 751's should have a tag stating drivers side, or if it is an older one, it will have an "A or B", A being for the drivers side.
What are you putting in the rear?
You might want to go rent a coil compressor from your local auto parts store, it will make the job much easier.
robdis96
Feb 22, 2013 07:07 PM
Lynwood
Jan 31, 2013 10:46 PM
wannabe
Feb 16, 2011 04:13 PM
lipadj46
Aug 18, 2009 08:28 PM
southfloridadiscoII
Jun 18, 2009 08:48 AM
