Front Washer Pump
Old Apr 17, 2009 | 10:15 AM
ih102's Avatar
6th Gear
Default Front Washer Pump
My front windshield washer pump is not working. Back pump works, the front light washers works. When I pull the windshield washer stalk, the light washer pump works and the windshield washers go but no sound from the washer pump.
Before I replace the pump, I'm wondering if there is a relay that I should check before I change the pump?
Old Apr 17, 2009 | 10:44 AM
It won't be a relay, remove and clean out your bottle, all lines and the nozzles to get rid of a build up of hard water crap.
Old Apr 17, 2009 | 11:30 AM
ih102's Avatar
6th Gear
Thanks Mike. I figured that there is nothing wrong with the lines because the pump is not actually making any noise.
Old Apr 17, 2009 | 12:02 PM
AK Rover's Avatar
Your front windshield sprayer pump will wear out and die a lot sooner than the others. It gets used a lot more. Your headlights sprayers on work every third time you spray the windshield and only if you have the headlights on. And how often do you really use the rear sprayer? I use mine probably twice a month.
Old Dec 13, 2011 | 08:34 AM
dparham's Avatar
I just read the RAVE on this procedure as I have same issue but none of my pumps work... it said remove front bumper... is this really necessary? I unplugged my line from engine bay to hood sprayers and tried to blow through it and could not.. maybe its too much pressure to get past the one way valve and not a good test? I can suck up from the tank but tastes bad.. lol
Old Dec 13, 2011 | 10:22 AM
Have you checked the fuse yet? How about the wiper switch hasve you tested to make sure it is working?
Old Dec 14, 2011 | 12:13 AM
dparham's Avatar
I tried fuse and wipers and even rear wipers and all work great.. just no sprayer.. I removed the drivers side light and could see the plug and I look it off and on a few times to see if it was a little corroded but still did not work... is it unusual to have all 3 of the pumps non working?
Old May 21, 2012 | 10:59 AM
dparham's Avatar
well Im back tackling the sprayer issue.... come to find out now that Im a little more experienced about When pumps activate we.. headlight pump works but sprays all inside finder so I guess hose is off... rear works great... no sound to main windshield washers... ( check valve was bad on on underhood hoses so ordered new hose kit there... however
1. do I really have to remove bumper to get to this?? ( 03 disco SE ...) no blown fuses...
Old May 21, 2012 | 01:51 PM
Discovery SE7's Avatar
I do it through the fog light. I just remove the driver side fog lamp and I can get to the pumps through there (at least the one on that side). Then I go from between under the car and the hood to access the others. It is really tight if you leave the bumper on, but it can be done. I have thin hands, so that also helps. If you have big hands, you pretty much have to remove the bumper.
I Haven't found a bad pump yet. I normally find the problem with the hose, a connection for a hose (like an elbow or T), or the sprayer. The hood sprayers seem to get caked up and get brittle a lot sooner than the others.
moorebl
Aug 28, 2013 12:57 PM
ertw67
Jul 7, 2012 10:24 AM
bosshogt
Feb 11, 2011 03:28 PM
krazzz
Jan 15, 2010 07:17 AM
R_Lefebvre
Jan 28, 2008 08:23 AM
