front wheel hub replacement
Old Jan 12, 2018 | 08:08 PM
CollieRover's Avatar
Originally Posted by Newscotlander
I have a 2004 Discovery that I purchased new and now use as a secondary vehicle. It currently has about 112,000 miles on it. I put between 2000 and 5000 miles on it annually and usually stay local.
The front wheel hub on the passenger side has gone bad and it needs to be replaced. I also need to replace the front brake rotors and pads. Does anyone have any experience with the wheel hubs on Amazon and made by TRQ (2 for $140)versus the one by British Atlantic (for $300)?
Note: I couldn't get the links to work.
Thanks.
I put in two hubs, I think 130 for both, off eBay in mine, and they’ve been on for a couple of years, and work great.
Old Jan 12, 2018 | 08:42 PM
Newscotlander's Avatar
Good to hear. Thanks.
Old Jan 13, 2018 | 08:14 AM
There are some good threads on hub removal, and I believe Offroadfrance pointed me towards a 3/4” breaker bar.I’d highly recommend that and a long section lead pipe. Also, I found an impact wrench really helpful.
Old Jan 13, 2018 | 10:27 AM
number9's Avatar
A decent 1/2" drive pneumatic impact wrench can shorten and/or make your day.
Old Jan 13, 2018 | 10:42 AM
Alex_M's Avatar
I'll double check my service book. I'm pretty sure I've got 15k+ on my oldest eBay cheapie and it's still holding strong. Nothing but good to say about them.
Old Jan 13, 2018 | 10:46 AM
I already have the passenger side off. Being as I'm from the Northeast, the rust slowed things down a bit but it wasn't too bad.
Do people recommend replacing the axle nut? I also hear that nut needs to be tightened to 360 ft/lbs though I haven't checked the service manual yet. I don't think my cheap torque wrench measures that high.
I have a 1/2" impact wrench but with all the bolts entering from the back, it is hard to work with it.
Old Jan 13, 2018 | 10:57 AM
I’m not sure how I lived without one.
Old Jan 13, 2018 | 10:59 AM
I used the impact wrench in the hub puller. Mine were rusted solid, and came off only under severe duress. I sued the impact wrench to tighten it up, and I may have been there all day without it.
Old Jan 13, 2018 | 12:23 PM
Alex_M's Avatar
Axle nut torque doesn't have to be precise. I've done... 5 D2 hubs, I think? Every single one I just roughly estimated the torque. For 360 lbs/ft, if you're using a 3 foot breaker bar that means you need 120lbs on the end of your bar, or if you're using a 2 foot breaker bar you'll need 180 lbs on the end of your bar. I take my breaker bar and just sit my body weight on the end. Maybe give it a bounce. That'll get you plenty close enough. You don't really have to worry about stripping the threads out, either, since it's so large.
Old Jan 14, 2018 | 08:27 AM
Good info, Thanks.
