Front wheel seal replacement?
Old Nov 30, 2010 | 11:59 AM
GARovee's Avatar
Default Front wheel seal replacement?
How much of a pita is doing the driver front wheel seal? I think mine is leaking...
Old Nov 30, 2010 | 02:13 PM
NiteTrain's Avatar
I did the seals on my D1 and it wasn't too bad..I'm trying to think which seal you're talking about on a DII..it's a unit bearing..do you mean the big O-ring in there?
Old Nov 30, 2010 | 02:57 PM
GARovee's Avatar
Ain't got a clue. Just noticed a lot of oil on that wheel on the outside.
Old Nov 30, 2010 | 03:25 PM
Can't be done, have to replace the entire hub assembly.
Old Nov 30, 2010 | 03:50 PM
NiteTrain's Avatar
which is $400
Old Nov 30, 2010 | 04:28 PM
GARovee's Avatar
Uhh some one built that assembly.. Why can't I rebuild it with a new seal? Just asking!
Old Nov 30, 2010 | 04:29 PM
Cause you can't and there are no parts available.
What exactly is leaking and from where? What color is the grease and is the hub warn/loose?
Old Nov 30, 2010 | 06:14 PM
lipadj46's Avatar
There are front axle seals.
Old Nov 30, 2010 | 07:53 PM
Yes, there are, that is why I wrote back and asked him where is is leaking from, the outer seal, being and bad hub or the inner seal, being gear oil.
outdoor7or24
May 21, 2012 08:34 AM
hhalimi
Feb 8, 2012 12:40 PM
04BluDisco
Oct 20, 2011 04:06 PM
LRD2&ME
Apr 19, 2011 02:42 PM
yloDiscoII
Feb 10, 2010 10:03 PM
