Front Window Issue
Old Feb 9, 2015 | 04:43 PM
CollieRover's Avatar
Default Front Window Issue
I replaced my window regulator and that is working fine. The piece that attaches the window to the regulator was badly rusted, and when the regulator failed that piece came loose from the window. I have it all the way up, but when going down it is getting stuck so I am assuming it is not just gravity that is supposed to keep the window attached..
Does anyone know if I can replace just that piece? Or do I need to get a new window? I have not found that piece on a website. Maybe a window shop has that piece?
Old Feb 9, 2015 | 04:57 PM
OverRover's Avatar
On the D1 it's ALR8022 > Window Lift Channel (ALR8022G Same Fit As Part # ALR8022 ) - Land Rover door catches\window regulators from Atlantic British the window goes in with glazing rubber and then into the channel.
I don't see the listing for the D2, but I would guess it called the same thing; WINDOW LIFT CHANNEL
This looks real close to alr8022 on a 2000+ D2 window http://www.ebay.com/itm/00-01-02-200...082ef5&vxp=mtr
Old Feb 9, 2015 | 05:07 PM
OffroadFrance's Avatar
If you cannot source a new part try Paul Grant on here as he breaks all types of LR's.
Old Feb 9, 2015 | 05:51 PM
Huge help guys thanks. I have to do the other front regulator as well, so will order one or two depending on whether that one is still attached.
twoxred
Oct 4, 2021 07:07 AM
jekylczar
Dec 7, 2013 07:45 PM
Motorvated
Aug 16, 2013 10:30 PM
kamileon
Apr 5, 2011 09:39 PM
bcolins
Oct 2, 2008 12:36 PM
