Front windshield and rear glass leak
Old Dec 6, 2019 | 08:27 AM
jsbutter's Avatar
Default Front windshield and rear glass leak
Happy Friday!
When it rains hard I have a puddle on my mat in the trunk. I can see where the water is coming in. The more concerning leak is my front windshield over passenger side. It has discolored the headliner slightly and will drip during a heavy rain. Any fix to this other than replacing the glass?
Thanks,
Old Dec 6, 2019 | 08:38 AM
boston4's Avatar
The rear alpine windows are common leak points - easy enough to reseal with silicone (the factory seal dries out and rots). For the front leak, it's common to have leaks along the A pillars, but if the headliner is getting wet I might suspect the sunroof drains as the culprit. Anything leading you to suspect the windshield rather than the sunroof?
Old Dec 6, 2019 | 08:42 AM
jsbutter's Avatar
Thanks for the info.
I don't have a sunroof. Can I do the same with silicone on the front?
Old Dec 6, 2019 | 09:00 AM
boston4's Avatar
For the seal across the top of the windscreen, yes, you can seal with silicone. If the leak is near the corners, check this thread:
https://landroverforums.com/forum/di...en-leak-90797/
Old Dec 30, 2019 | 06:51 PM
jsbutter's Avatar
I also have a lot of water passenger side floor mat. When it rains hard, it is soaked. Any idea where this water is coming from?
Old Dec 31, 2019 | 12:55 PM
XRAD's Avatar
fresh air intake for cabin blower is common culprit for passenger side puddles .....
bcolins
Nov 28, 2024 05:03 PM
earlyrover
Mar 27, 2017 03:41 PM
capecodjim
Mar 13, 2013 11:34 AM
MC04DII
Feb 6, 2013 11:32 PM
And4848
Nov 20, 2008 02:29 PM
