Frustratingly inconsistent AC system
Old Jul 15, 2019 | 08:52 PM
Ben Matheson's Avatar
Originally Posted by Llamasayswhat
How did you manage all that, but you're unsure on weight? Any Automotive AC machine is going to do all of that on an auto cycle with no questions asked.
Gauges and vacuum pumps are cheap and available for free use from auto parts stores. Getting a precise weight into the system is very difficult when trying to weigh little cans of r134.
Old Jul 15, 2019 | 08:53 PM
Originally Posted by Jason Feuerstein
I had to compensate for refrigerant left in the hoses. The RAVE manual has a calculation for that, but it's not perfectly precise; hence why there's some leeway in the amount of refrigerant used.
What did you end up with for final high and low pressures and at what temp outside
Old Jul 15, 2019 | 08:56 PM
redwhitekat's Avatar
You need to pressure test at least 150 psi for a good hour
than if it holds you evacuate to at least 4-500 microns
than you get a weigh scale get your jug of 134 a and weigh in charge
done
reggie77
Nov 9, 2018 07:41 PM
DieHard
Jul 14, 2017 09:19 AM
Brianjw82
Aug 26, 2012 10:36 PM
nelsontod
May 19, 2012 09:25 AM
The Cisco Kid
Jun 8, 2011 04:18 PM
