fu o2 senser
Old Feb 26, 2014 | 05:56 PM
cornbreadj's Avatar
Default fu o2 senser
Y won't you come out you mother f&%ker sorry just frustrated
Old Feb 26, 2014 | 06:48 PM
Charlie_V's Avatar
There a socket attachment at most car places that will take them off the front driver one is hard to reach. I used a 3/8 socket with the attachment and a short extension.
If you are positive you won't need the old o2 sensor you can just grab some pliers and show it who's boss.
Old Feb 26, 2014 | 07:16 PM
cornbreadj's Avatar
I have a new one. I put channel locks on it only turned about 1/4 of a turn then nothing. And yes its driver side
Old Feb 26, 2014 | 09:24 PM
TripleThreat's Avatar
Soak it down with PB Blaster...
Old Feb 27, 2014 | 06:32 AM
Ghaniba's Avatar
Most important thing - Do it after the truck is hot, and exhaust is hot. Usually come out like butter. Yes, be careful not to burn yourself.
Dave
Old Feb 27, 2014 | 08:08 AM
grandkodiak's Avatar
think you cursed me, my check engine lights on and the pass side o2 is taking forever to start reporting real data. jerk.
Old Feb 27, 2014 | 08:21 AM
cornbreadj's Avatar
The pass side was not to bad to get out its the driver side
Old Feb 27, 2014 | 11:01 AM
jfall's Avatar
Don't try to simply unscrew the sensor.
You need to unscrew it till it binds.
Then do the other direction then you will unscrew a bit more
until it binds.
Then back in.
That way you will not strip the threads in the pipe.
And yes.
PB blaster
WD40
Put all this on and let it soak.
And blast it on when removing.
Last thing --
All that will work is VICE GRIPS.
Channel Locks - NO.
OR - Hack saw the thing off until just the bolt part is left.
Then use a socket.
(put a rag over your nose and mouth)
Still - in and out in and out to get it off.
Landlover12
Apr 2, 2011 12:27 PM
redw&blue
Oct 15, 2010 10:05 AM
ERICM63
Jan 13, 2009 12:35 PM
asat
Nov 3, 2008 09:59 PM
