Stalling 2002...Crank pos senser????
Old Nov 3, 2008 | 08:05 PM
asat's Avatar
Default Stalling 2002...Crank pos senser????
Hi to all,
Here's my story
2002 range rover 115k miles
no problem when starting cold
The car runs for around 10 minutes or miles give or take, Idle or driving, and then stalls, cranks fine but won't start for anywhere from 10 to 35 minutes, then i drive another 10 miles or so, stalls and then i have to wait and start the whole process over again.
I was told it was a fuel pump, replaced it but problem still there.
These are the codes read off snap on modus generic tester
po355 crank pos sensor
po101 mass air flow circuit range
p1669 manf specific
p1884
manf specific
I was now told by a rover tech to replace the crank position sensor, and that this was a common problem with this truck and will fix my problem.
Before I do it, I was hoping for some other opinions
All help is much appreciated!!!
thanks in advance!
Adam
Old Nov 3, 2008 | 09:59 PM
tacomatech's Avatar
Default RE: Stalling 2002...Crank pos senser????
I agree with that diagnosis, as far as the no-start issue goes. It is a very common issue with these engines, both in the Range Rover and in the Discovery II's.
cornbreadj
Feb 27, 2014 11:01 AM
Landlover12
Apr 2, 2011 12:27 PM
redw&blue
Oct 15, 2010 10:05 AM
ERICM63
Jan 13, 2009 12:35 PM
suntattoo80
Jun 13, 2007 08:37 AM
