Fuel Gauge wont go above red
Old Mar 15, 2022 | 07:23 PM
fieldeffectt's Avatar
7th Gear
Default Fuel Gauge wont go above red
Hello everyone, new to the Disco 2 world. Picked up a 2003 a few weeks ago, it has an issue where the fuel gauge wont display the proper amount of fuel. I got a P0463 code : "Fuel level Sensor A circuit High" I went ahead and swapped the whole fuel pump assembly "Unit" with one that worked from a Donor Disco 2 (Same year) but i still have the same issue where the gauge wont go up passed the red line no matter how much fuel is in the tank. The wire to the connector looks fine. Is there anything else I can look for? Fuse or something?
Thanks in advance!
Edit: I installed the questionable fuel pump assembly into the donor car and the gauge worked just fine. So its something else in the car, but im not sure what else to look for.
Old Mar 15, 2022 | 09:17 PM
greisinb's Avatar
Did you clear the code? The gauge might still read bad if the code is present, but that seems odd to me.
Old Mar 15, 2022 | 09:23 PM
Harvlr's Avatar
I’m not the expert but I think my next step would be to start ringing out wiring, maybe a poor ground or corroded connector somewhere?
redrover75
Jun 23, 2020 11:48 AM
glennforbes@rocketmail.com
Jan 31, 2020 11:15 AM
CollieRover
Nov 29, 2018 09:37 AM
Dwimmerlaik
Apr 26, 2012 04:05 PM
40ranger
Apr 7, 2008 12:20 AM
