fuel injection
Old Jun 26, 2010 | 02:54 PM
kemil77's Avatar
Default fuel injection
On discovery 2 year 2000. Wht type of fuel injection is on the 4.0
Old Jun 26, 2010 | 02:58 PM
All DII's have Bosch engine management.
http://www.roverparts.com/Parts/ERR6600K.cfm
Old Jun 26, 2010 | 03:04 PM
kemil77's Avatar
I cnt seem 2 find the fuel relay switch 2 decompress the fuel pressure. The rave states its on the firewall dnt see it
Old Jun 26, 2010 | 03:23 PM
Rovin4life's Avatar
its underneath the fuel rail.
Let me guess your vehicle turns over but won't start. If it does that then it most likely needs a crank shaft position sensor. If you think it still needs a fuel pump then jump the relay and listen for the pump.
Old Jun 26, 2010 | 03:35 PM
kemil77's Avatar
It starts I'm getn ready 2 disassemble tha heads
Old Jun 26, 2010 | 07:35 PM
Just pull the fuel pump fuse from the fuse box with the engine running.
Once it stalls turn the key off and put the fuse back.
JumPeR04
Apr 1, 2011 04:15 PM
lennie5936
May 7, 2008 09:07 PM
bobm
May 6, 2008 08:18 PM
kenlen
Apr 21, 2007 07:08 PM
savatage
Feb 12, 2007 07:25 PM
