Fuel Line Connection
This will be an easy question, but I wanted verification.
I am replacing the head gaskets on my 99 Disco II. I have the lower intake loose and need to disconnect the fuel line from the intake. I assumed the line was connected by a compression fitting but have not been able to get the line to let go.
Is this a compression quick disconnect type connector? If so, what size removal tool should I be using.
Thanks for any response.
Bigun
Bigun
On my 03 there is a green rubber boot that covers the fuel line at the fuel rail. You can sort of peel the boot backwards and you'll see exactly how it works. You have to depress the grey button part of it and pull it back. you can sort of see part of it here...
JerrodSteph
Jun 12, 2011 06:04 PM
JumPeR04
Apr 7, 2011 09:52 PM
DealLot.com
Member Group And Special Buys
Jun 11, 2007 11:42 PM
DealLot.com
Jun 11, 2007 11:41 PM
Doing the same with my DII. Thanks for the thread.
