Fuel pump changed now it hesitates to fire.
Old Jun 3, 2010 | 12:08 AM
Whitepine's Avatar
4wd High
Default Fuel pump changed now it hesitates to fire.
I just changed out the fuel pump and filter. The pump was dead. The truck fired right up after I changed out the pump, but now it is hard to start. If I just turn the key with out hesitating, it will not fire. If I turn the key and wait for the pump to come on for a about 5 seconds, It will usually fire, but I may have to give it a little gas. Any Ideas?
Cheers, Whitepine
Old Jun 3, 2010 | 12:40 AM
ljdiscovery's Avatar
If it is a DI, you might want to change your fuel filter. If it is a DII, no fuel filter. Sounds like you aren't getting sufficient pressure from the new fuel pump. YOu can check the fuel pressure at the fuel rail using a fuel pressure gauge. You should be showing 35 lbs. give or take as I recall. Phil
Old Jun 3, 2010 | 08:07 AM
The pump you installed, was it a brand new one from Rover or an after market, also did you replace the entire pump assembly or just the pump?
Old Jun 4, 2010 | 12:17 AM
Whitepine's Avatar
4wd High
I replaced just the pump with the airtec pump and a new strainer. I am going to check the fuel pressure at the rail this weekend and check for any leaks.
Old Jun 4, 2010 | 09:41 PM
CHANGE THE FUEL FILTER!!!!
If the filter is clogged it will overwork the pump and burn it up as well as cause hard starts.
Old Jun 5, 2010 | 03:08 AM
Whitepine's Avatar
4wd High
I changed the pump and strainer along with putting in a new fuel filter. Are you saying I should now replace the "new fuel filter" too.
Cheers, Whitepine
Old Jun 5, 2010 | 08:11 AM
Rovin4life's Avatar
what is your fuel pressure reading and is it keeping pressure?
Old Jun 5, 2010 | 09:56 AM
kenk's Avatar
Check your fuel pressure after it has sat for a few hours. Sounds like your check valve in the sending unit is not holding pressure when off.
Old Jun 5, 2010 | 01:27 PM
greg409's Avatar
A good fuel pressure ga is a wonderful thing to have, however, when I check(ed) mine, I used a fairly cheap $2 tire pressure ga. (that was over a year ago & ga still works fine)
Protect yourself with an old rag.
Kenk is dead on, it should hold pressure for at least 1/2hr after shutdown.
luck,greg
Old Jun 5, 2010 | 01:41 PM
Rovin4life's Avatar
luck,greg
like that idea for D2s.
