Fuel pump difference: sai vs non sai
Old Aug 31, 2012 | 11:02 PM
roverbob's Avatar
Default Fuel pump difference: sai vs non sai
Does anyone know what the difference is supposed to be between fuel pumps from disco 2's circa 2001 in trucks with sai vs non sai trucks?
I've got one of each- supposedly- I've looked them over pretty good, and the only differences i've found are
color of the plastic (sai car is darker)
material internal connections are made of
unfortunately i didn't get pictures of the one that went into the truck before i realized there's supposed to be two different types, i just checked it all with a multimeter and put it in...
Supposedly the fuel pump in the truck now is for a non-sai truck, but it's just fine, no CEL no running issues etc
anyone got any insight? googles been useless beyond telling me there's two different part numbers and the more popular one is more money
Old Sep 1, 2012 | 12:55 AM
jfall's Avatar
I do not think SAI vs NON SAI would have a different fuel pump.
The fuel system and fuel pressure are not related to the SAI.
SAI is simply a shop vac that blows air into the heads when the Rover first starts in the morning to prevent pollution.
IF your fuel pumps looked different, probably one is OEM and one is an OEM from a different vendor.
Old Sep 2, 2012 | 08:24 PM
roverbob's Avatar
certain vendors certain years list seperate fuel pumps
rockauto does not acknowledge vehicles with SAI (see below) but has the best price on a bosch pump
What's struck me is that they don't have seperate pictures. rovers north for example shows you a picture of the sai FP and a diagram for the non sai FP. parts geek seems to have inverted one pic.
My truck is a 2000 sai, and partsgeek says only one pump for that year, but i had a spare pulled from a 2001 non sai which i put in and doing due dillegence post-facto on the functioning repair job i found out vendors are claiming some years have "options".
i'm wondering if it's as simple as the cylindrical mounting tab for the black sensor to fuel system vac line (circled in the attached picture) sorry I don't have a grasp on the proper name for what that sensor is
ie partsgeek roversnorth (90$ difference) atlanticbritish
this is all cut and pasted except partsgeek bc their site is a mess
@partsgeek LR D2 2001
Bosch Fuel Pump Assembly
Part Number: W0133-1597624
Notes: w/ Secondary Air Injection
Detailed Notes: Includes Sending Unit. Tank Seal Serviced Separately.
$319.10
Part Number: W0133-1597574
Notes: w/o Secondary Air Injection
$362.10
Note the one for non-sai is more $.
Roversnorth:
FUEL PUMP/SENDER ASSEMBLY DISCOVERY II
E-mail this product to a friend
Fuel Pump.
Fits:
Discovery II with secondary air injection
Part#:RNE009Price: $399.95
PUMP - FUEL TANK UNIT DISCOVERY II
Fuel Pump
Fits:
Discovery II w/o secondary air injection
Part#:RNH295Price: $489.95
ROCKAUTO:
Fuel Pump </SPAN>Related Parts2001 LAND ROVER DISCOVERY 4.0L V8 : Fuel/Air : Fuel Pump WikiPriceBOSCH Part # 69340
For vehicles without secondary air pump; Engine VIN 2
For vehicles without secondary air pump; Engine VIN 5* Stocked in outlying warehouse--shipping delayed up to 2 business days$304.99Add Part
Idle Air Control (IAC) Valve
Old Sep 2, 2012 | 08:30 PM
roverbob's Avatar
SOLVED
it's the pressure sensor for the evap system check out atlantic british they know their stuff
Fuel Pump With Sealing Ring
Item: WFX101070K
In Stock: Yes!
Fits:
Discovery Series II | '99 - '04 | TO YA290236 HAS PRESSURE SENSOR CHECK TRUCK TO SEE IF INSTALLED
Our Price: $399.95
Qty
Item: WFX101060K
In Stock: Yes!
Fits:
Discovery Series II | '01 - '04 | FROM 1A290237 -DOES NOT HAVE PRESSURE SENSOR FOR EVAP LOSS SYSTEM
Our Price: $379.95
Old Sep 2, 2012 | 08:34 PM
roverbob's Avatar
anyone wondering- if sensor is good you can swap it over
gatorm
Aug 11, 2017 04:04 AM
Drillbit
May 28, 2014 12:34 PM
Jim Vargas
Freelander
Sep 6, 2012 08:50 AM
Paul Grant
Jun 9, 2012 07:00 AM
uh60driver
Apr 2, 2012 11:22 PM
