Fuel pump regulator or leaking injector?
Old Oct 5, 2019 | 11:34 AM
sickws6's Avatar
Default Fuel pump regulator or leaking injector?
Yes I know the regulator is internal to the pump.
Here is what is going on.
Connect fuel pressure gauge.
Turn imagination to on poison and see gauge flutter up to maybe 20 then immediately leaks back down.
Crank the engine for 5-8 seconds and Engine starts finally while pressure was increasing entire duration of cranking.
Engine runs flawlessly with solid steady fuel pressure at around 48psi.
Turn key off and pressure drops immediately to 0.
No missfires or black smoke.
Old Oct 5, 2019 | 01:12 PM
sickws6's Avatar
Never mind. Narrowed it down to pump check valve.
lestro
Feb 22, 2017 10:04 PM
bcbp
Jan 12, 2014 12:17 AM
Akumal
Nov 6, 2012 03:04 PM
leadfoot
Sep 14, 2009 10:55 AM
