Fuel pump removal- help
Old Feb 16, 2014 | 04:48 PM
Richard.rover's Avatar
Default Fuel pump removal- help
Guys does anyone know how to remove the adapter ring on the d2 tank? It goes between the tank and locking ring. It is rusted and keeps giving me a evap code. I have tried to turn counterclockwise and it turns but won't come loose. It has gone 1/4 turn but I figured it should loose now. Any one?
Old Feb 19, 2014 | 05:28 PM
Here is a look at the part
Old Feb 19, 2014 | 05:30 PM
Another
Old Feb 23, 2014 | 09:14 PM
Installed the adapter ring and got the seal in. Here's a pic of the finished stuff. Had to use wd40 and used the locking ring to spin the adapter on.
Old Feb 23, 2014 | 10:46 PM
Dane!'s Avatar
Whyd you take the pump out in the first place? Did you think the seal was bad? Only reason I ask is because I thought my seal was bad, but I ran the truck with the fuel pump exposed and it turned out to be my fuel pump was cracked. my luck >
Old Feb 24, 2014 | 09:50 AM
I pulled because I had a recurring evap code. The ring was cracked and seal was folded. The truck runs fine now. My pump wasn't cracked. Good for me��
Old Feb 24, 2014 | 11:40 AM
Dane!'s Avatar
I'm glad it worked out! Weirdly enough I didn't code at all, I just had problems starting and a fuel smell on the rear
Old Feb 25, 2014 | 07:37 AM
Sorry forgot to mention. I filled up one day and I had some fuel spillage. Checked and found that ring rusted and the locking ring loose. Replaced both to avoid future problems.
jycsalas
Aug 5, 2023 09:24 AM
Travelor
Sep 24, 2015 06:11 PM
Danobp
Jun 3, 2014 04:15 AM
JumPeR04
Apr 7, 2011 09:52 PM
