Fuel Pump Wiring plugs
RE: Fuel Pump Wiring plugs
you want to check for power at the white and purple wire after you turn the key on, if you dont have power, theres no point in checking if the pump is good, its not working because theres no power. first thing to check is your inertia switch, rear pass side of the engine bay, little button looking thing on the firewall, press the top, make sure the button in it is switched closed.
Thanks, great help, power at the white/purple, so now I guess the pump, she is dead??
I was checking the plugs, but I guess I didn't get to the proper one before the 30 seconds
were up. One would think the red would be power, but that would be too easy. Now I will start the search for a pump. Thanks again, Paul
marsyas
02-25-2021 08:11 AM
Travelor
09-24-2015 06:11 PM
JumPeR04
04-07-2011 09:52 PM
