Fuel Pump Wiring plugs
Old May 23, 2008 | 05:48 PM
pcrightler's Avatar
5th Gear
Default Fuel Pump Wiring plugs
can anyone tell me what the pins are in the two wiring plugs to the fuel pump, and should I have power to anyone of these pins with the key on???
Old May 23, 2008 | 07:35 PM
Default RE: Fuel Pump Wiring plugs
Are you talking about the connector at the pump? What year is your trk? The fuel pump gets power and will run to build fuel PSI for about 30 seconds, if the engine has oil pressure then the pump will continue to run.
Old May 23, 2008 | 09:38 PM
roverguy7's Avatar
if you have two, then the one that points down is for your pump and sender unit. the other is your fuel tank pressure sensor. and yes, there should be power for a few seconds after key on on one of the pins, which one depends on what year
Old May 24, 2008 | 10:38 AM
pcrightler's Avatar
5th Gear
I have two plugs, one 3 wire(red, black, striped) one four wire . is the three wire (red,black) the power , ground to the pump, if so, may I jumper to the red,black to see if the pump works, then look to see why I don't have power to the plug????
Thansk, Paul
Old May 24, 2008 | 10:39 AM
pcrightler's Avatar
5th Gear
sorry, this is a 1997 disco
Old May 24, 2008 | 10:59 AM
roverguy7's Avatar
you want to check for power at the white and purple wire after you turn the key on, if you dont have power, theres no point in checking if the pump is good, its not working because theres no power. first thing to check is your inertia switch, rear pass side of the engine bay, little button looking thing on the firewall, press the top, make sure the button in it is switched closed.
Old May 24, 2008 | 11:15 AM
pcrightler's Avatar
5th Gear
Thanks, great help, power at the white/purple, so now I guess the pump, she is dead??
I was checking the plugs, but I guess I didn't get to the proper one before the 30 seconds
were up. One would think the red would be power, but that would be too easy. Now I will start the search for a pump. Thanks again, Paul
Old May 24, 2008 | 12:44 PM
roverguy7's Avatar
just to be sure, you should check ground at the pump too, easy way for this is if you have any fuel gauge reading at all on your instrument pack, its good and you need a pump
Travelor
Sep 24, 2015 06:11 PM
OffroadFrance
Off Topic
Jan 14, 2015 04:56 PM
JumPeR04
Apr 7, 2011 09:52 PM
akc
Sep 28, 2008 02:26 PM
