Fuel relay, coil relay question 03D2
Hello everyone, I need a little help. (03D2) I have replaced my timing chain set, oil pump gear and front seal. I packed the oil pump with vasoline and oil, changed the oil and filled the filter. I now would like to spin the engine to prime it all up and get oil pressure before starting the engine.
I would like to locate the fuel pump relay. I see in my fuse box under the hood one of the relays has a gas pump on it, is that the correct relay to pull? and if so is it the only one I need to pull? also should I pull my coil relays? If so where are they located. I see two relays with an engine with a lighting bolt running through them. Are those the coil relays? If so do I pull them both? I could probably dig and research and find the answers, but it would take me half a day and I need to be working on the truck before it rains again the afternoon. Any help would be appreciated? Thanks
Not sure about the relay, but the inertia switch that is at the firewall on passenger side will stop the fuel pump from working but allow the engine to crank.
Black switch mounted in the upper section, has 2 Phillips head screws holding to to the firewall. The top has a rubber cover on it. This is the switch that trips when in an accident or rollover scenario. You push down on the rubber top/ button to reset.
In your case, just disconnect a wire.
I think I have decided R1 is the fuel relay, so what about coil relay? would that be R6 and R9? I can't find this in the rave and have looked for an hour? I can't get around in there very good? Not too computer savy. I have to wade through page by page. Don't know where the diagram for the fuse/relay block is in the rave?
I'll just unplug the inertia switch like abran said for the fuel and then reset it, still don't know about the coils? does it matter if they are firing while I'm spinning the engine with no fuel while priming the oil up? Pink Floyd and I would both like to know "is there anybody out there?" I need to do this asap before the rain. Thanks
Just start it up.
If the oil light stays on past 10 seconds, shut it down.
No need for all this ultra caution.
If you want to kill the fuel pump, look in the owners manual for the fuel pump fuse.
Pull it and crank away.
With no pressure in the fuel rail, the truck will not run.
New oil pump, new timing set, new head gaskets, rebuilt heads, valley gasket, valve cover gaskets, new crank sensor, oil pan gasket, all new hoses, new belt, new 180 gray thermostat, new coolant bottle, new coolant cap, new water pump, bypassed throttle body heater.
Travelor
Sep 24, 2015 06:11 PM
