Fuel/Spark issues maybe?
![Question](https://landroverforums.com/forum/images/icons/icon5.gif)
So I put new plugs in a had the codes read this morning and only these three came up this time and I was about to buy 2 o2 sensors for the 2 on bank 2.
P0174 = System Too Lean
P0150 = o2 sensor circuit malfunction (bank2 sensor1)
P0159 = o2 sensor CKT slow response (bank2 sensor2)
So I am going to replace both o2 sensors tomorrow and hopefully this takes care of the issues.
Here my next questions:
Should I then also clean the injection system, throttle body?
I saw a post for this on the D1 is it the same for my d2? Mike what would you recommend I use for this?
Thanks again for all the help with.
I just want to make sure this is what is meant.
Thanks again for all your help I am leaving now to go get the o2 sensors.
I would do the throttle body cleaning and induction cleaning now, then new plugs and O2's when they all come in.
![Thumbs up](https://landroverforums.com/forum/images/icons/icon14.gif)
Alright...
So last night I did the induction cleaning and the t-body just like Mike outlines in his post. Smoked the whole street out, everyone on my block got a kick out of it and when I got back home after 20 miles of driving it out, there was a "party" going on in my driveway. They all wanted to talk to me and figure out what I was doing to that $50k+ Range Rover, even though I have already told them its a $8k Discovery - I always get that or the "Toyota makes that right?".
Then this morning I put the new o2 sensors on and a full set of 4418 +4 plugs (again).
She runs beautifully, like the day she was new. Its amazing how much better it idles and feels like it has way more power.
Its idle is right at 600, is this right or should it be a little higher?
Thanks again and again you guys have really helped me out and probably saved me a couple of thousand dollars since i started on this forum.
So everything was running great for about 2 weeks now and yesterday it comes back. Do you think I bought bad o2 sensors?
The idle is low again and at low rpm's it rides ruff.
Here are the codes that came up yesterday:
P0150 - o2 sensor circuit malfunction (bank2 sensor1)
P0174 - system too lean (bank2)
P1174 - manufacturer control fuel/air metering
P0159 - o2 sensor CKT slow response (bank2 sensor2)
I still have the receipts from the o2 sensors. Do you think I should try to go to the auto parts store and make them replace them?
Thanks for the help guys-
