Fuel spill under the truck on Fillup
Old Oct 20, 2024 | 04:58 PM
mln01's Avatar
Default Fuel spill under the truck on Fillup
A friend here has an ’01 DII. The last couple times he’s gotten fuel there’s been a fuel spill under the truck.
In his words,
“The last two times filling up at Costco, I had gas running all over the place. As near as I can determine it is coming from the top of the fuel tank. It only happens when the tank is full. I heard what sounded like a belch and there was a huge puddle of gas under the car. First time it happened it was simultaneous with the auto shutoff.
The second time I did not wait for the auto shutoff. Filled the tank very slowly and just as I was finished it belched and there was a 7-foot puddle of gasoline under the car.”
I don't recall reading anything like this in my 15 years on this and other forums. My guess is the connection between the filler tube and the tank has failed such that fuel flow into the tank with no problem but leaks once the tank is full, but to me that doesn't explain the "belch" sound he describes. Any ideas?
Old Oct 20, 2024 | 05:01 PM
Harvlr's Avatar
No CEL? You’d think there would be an Evap system error.
Old Oct 20, 2024 | 05:26 PM
mln01's Avatar
Nope. The instrument panel is dark.
Old Oct 20, 2024 | 07:28 PM
Extinct's Avatar
He will need to get under truck and see where the spill is coming from, could be vent hose to the filler neck, could be evap hoses on top of tank. The other option is to remove or cut the carpet in the cargo hold and observe top of the tank.
Old Oct 20, 2024 | 08:06 PM
mln01's Avatar
Thanks Extinct. Yeah, we figured we'll need to do that. I was just wondering, before we dive in, if anyone here has encountered this.
Old Oct 21, 2024 | 11:01 AM
JohnZo's Avatar
Both my D1s had failed vent tubes that leaked gas.
Old Oct 21, 2024 | 02:35 PM
whowa004's Avatar
not in my D2s but my classic has a blown/rotted vent hose that will leak upon filling all the way up..not overly difficult to fix but the replacement hose lasted all of 6 months or so which is pretty annoying. Going to just get my own hose next time I feel like replacing it.
Old Oct 23, 2024 | 12:33 AM
miron's Avatar
If you lived in Seattle it would probably be caused by some bum drilling a hole in ur tank in order to drain it.
Old Oct 23, 2024 | 07:18 AM
zski128's Avatar
Had a similar problem. The top of the fuel pump plastic flange had loads of cracks in it. Fuel pump metal flange needs to be replaced. I had intermittent evap codes.
Old Oct 29, 2024 | 07:39 PM
mln01's Avatar
My friend and I met at a gas station to try to find the source of the leak.
He replaced the fuel pump several weeks ago, so in addition to keeping an eye under the truck we pulled back the carpet and removed the fuel pump access panel. As the tank approached full, the leak became apparent.
The “moat” around the top of the fuel pump began filling with gasoline, indicating the fuel pump locking ring. He told me he didn’t replace the sealing ring that’s under the locking ring when he replaced the pump, so now he gets to disconnect the wiring and the fuel line to remove the locking ring and install a new sealing ring.
The electrical connectors are easy, but he said reconnecting the fuel line was a bit of a struggle he’s not looking forward to doing again. I took the pic after we’d mopped up the spilled gas. I wish I had taken it showing the fuel in the moat.
This doesn't explain the "belch" noise my friend described, but the leak is the same as zski128 described.
