Fuel tank pressure sensor fualt
Old Nov 3, 2019 | 07:03 PM
Chrisw329's Avatar
Default Fuel tank pressure sensor fualt
2000 disco here I know I need to get to updating my sig!
so I am down to the last code I have for the minute and my foxwell only gives me DTC codes? I don't get the regular PXXXX codes I see mostly around here. anyways the first one was the purge canister vent valve code. I found out that one was from a plug in what I am assuming was the canister after reading some other threads around here. cleared codes went for a drive turned off car and then back on to see if anything showed up now I only have the second fuel tank pressure sensor fault. I think thats going to be on top of the fuel tank from what I am seeing on here. I found a harness on the passenger side near were the other plug was that was not plugged into anything. I know it might be for some feature I don't have since there are plugs all over for things like that just wondering if it could possibly go to the sensor. I tried looking for this combination of colors in the rave but did not come up with anything. anyways hers a picture of it its near the firewall on the battery side.
60 DTC---Purge cannister vent valve/DMTL power stage fault
63 DTC---Fuel tank pressure sensor fualt
Old Nov 3, 2019 | 07:24 PM
Best4x4's Avatar
Looks like the connector for the cruise control pump.
Old Nov 4, 2019 | 03:41 AM
JUKE179r's Avatar
Yep. cruise control pump... purple and green wire.
BTW... where is your Secondary Air Induction (SAI) pump filter? The inlet is taped off.
Old Nov 14, 2019 | 08:40 PM
Chrisw329's Avatar
Yeah it was missing the cruse control pump picked one up at the scrap yard but still no cruise I read it may be because horn relay is taken out or a fuse or might just be an air leak I haven’t got to look yet. I did get all the codes gone for now tho it was the sensor on the fuel pump. Replaced whole fuel pump since I didn’t see anywhere to get just sensor. What does the secondary air induction do it’s probably missing that too 😦
paul1454
Feb 18, 2020 04:03 PM
BOZA
Apr 20, 2017 07:50 PM
tcr6v1
Feb 1, 2017 02:11 PM
chubbs878
Aug 16, 2015 11:48 PM
CODisco2
May 13, 2015 03:44 PM
