Fuel Tank Vent Line Replacement.
Old Mar 30, 2008 | 03:17 PM
Landzu's Avatar
Default Fuel Tank Vent Line Replacement.
Here are afew Pictures
[IMG]local://upfiles/649/D0B8978D531F40DAA0F07C4624EE9F6B.jpg[/IMG]
This is where I dropped the sway bar.
[IMG]local://upfiles/649/60C2421DA9B84D928F6814DAA9D79F83.jpg[/IMG]
[IMG]local://upfiles/649/02C90F30460843C88AB995174918234F.jpg[/IMG]
This is part of the vent line that needed replacement.
[IMG]local://upfiles/649/B85D58B430E647C195A13F3C19DCAEF6.jpg[/IMG]
The fuel tank looks small setting there,,, Its much larger when I fill it up.
[IMG]local://upfiles/649/FCC72E9888044C4B9E36DCE5A7A1D6ED.jpg[/IMG]
The vent line that needed to be replaced.
Old Mar 30, 2008 | 03:25 PM
Landzu's Avatar
Default RE: Fuel Tank Vent Line Leak
Here are the rest of the Pict's
[IMG]local://upfiles/649/1F21FE41759E46C68882172B579A33D1.jpg[/IMG]
[IMG]local://upfiles/649/0DBB5F8009C241BA90B2F28C3726587D.jpg[/IMG]
Old Mar 31, 2008 | 07:27 AM
cplthomas's Avatar
Thanks for the pics! I actually need to replace mine too, now I know what kind of job I am in for.
Old Mar 31, 2008 | 08:16 AM
Landzu's Avatar
I had to replace the hose at the gas filler neck first and did not have time to do it so I spliced in a 1/2" copper pipe and
3/4" gas line.
It lasted about 3 mo's then I did the rest.
There is a small black plastic line that has a quick release and then there is a line holder that is red that needs to be pushed in as you pull the line out.
I did not loosen the top strap that holds the tank from the top, but I did run the fuel very low, I never knew that the little yellow light would come on.
I think I had about 1 1/2 gals left and that made the job much easier.
Doing at the shop that I manage with a lift was better that doing on my back on ramps.
It took about 1 1/2 hrs from start to finish.
Get 3/4" inch gas line (I had 3 feet)and new hose clamps.
Old Sep 12, 2008 | 04:32 PM
Landzu's Avatar
Zracin I hope this helps.
Old Sep 12, 2008 | 08:26 PM
Landzu's Avatar
Zracin to lower the tank any you will have to unhook the
fuel pump,, the vent and filler hoses and then the
two straps not at all hard.
It would be just a easy to drop the tank all the way.
If you do and have a OEM tow hook watch how it drops
down as the tank will have to go in at the back first to make it easier.
Old Sep 13, 2008 | 12:06 AM
sdsilvere38's Avatar
What was actually leaking? Reason I ask is because when I fill up at the pump my truck leaks some gas right beneath the filler neck when the gas is pumped fast.
Old Sep 13, 2008 | 07:33 AM
Landzu's Avatar
The large vent line 3/4" on top of the tank .
It was leaking next to the tank a small little crack in the line.
Old Sep 13, 2008 | 11:32 AM
Landzu's Avatar
This a PRE advanced EVAP system if you have a early 96 or older Disco I this
what you have.
Travelor
Dec 4, 2022 09:51 PM
geek_IM
Mar 31, 2018 03:03 PM
photo2u
Oct 13, 2014 04:02 PM
JustTani
Oct 9, 2014 01:42 PM
JavaDiscoII
May 16, 2010 03:34 PM
