Function of shims backing brake pads ?
Old Dec 2, 2017 | 05:08 PM
Externet's Avatar
Default Function of shims backing brake pads ?
What do those thin shims do, and what are the dangers if found not installed to the brake pads ?
Old Dec 2, 2017 | 06:10 PM
Red5's Avatar
The shims provide a bit of cushion between the pad and the caliper and help eliminate brake noise. It they're gone, your brakes may squeal a bit more than they should.
Old Dec 2, 2017 | 09:47 PM
Greg Vasileff's Avatar
Also help reduce heat transfer. If missing I would not worry about it at all, unless they got loud.
Old Dec 3, 2017 | 08:50 AM
Best4x4's Avatar
You can apply some caliper silencing goo (don't know it's actual brand name) between the caliper and the brake pad "if" they squeal.
BCDisco2Lando
Feb 19, 2014 10:21 PM
jastutte
Apr 28, 2013 02:39 PM
coors
Apr 10, 2011 12:44 PM
Rover Chris
Dec 5, 2010 03:46 PM
mrossipir
Oct 9, 2009 05:11 PM
