Funky dash light issue
Old Jun 26, 2012 | 11:33 PM
nadylime's Avatar
Default Funky dash light issue
One of my friend's house flooded in the storm today and I helped him move his stuff out - in the process of this I drove through about 3 feet of water a few times & was submerged for about 30 minutes.
Now, when I turn the truck off the dash lights still stay on. I can press the brake & they turn off, but when I let up they turn back on again. Any ideas on what this might be? I disconnected the battery cable so the battery doesn't drain, but that's only temporary.
Also, should I check anything else on the Disco having driven it through that deep of water?
Fyi, the engine compartment is dry.
Thanks much!
Old Jun 27, 2012 | 12:13 AM
Bkreutz's Avatar
Did you get water into the interior? If so check under the seats for water ingress into the wiring/control boxes/relays.
Old Jun 27, 2012 | 01:33 AM
FlyingZebra34's Avatar
the only reason I can see causing that issue is water causing some wire somewhere to make a connection that it isn't supposed to make. leave the battery off until the truck has time to completely dry then plug everything back in. If the problem persists then some electrical damage has been done and finding the problem is normally a pain.
Old Jun 27, 2012 | 05:52 AM
drowssap's Avatar
you didnt think 30 inches of water was a little much? it's only 9 inches of what LRNA limit.
Old Jun 27, 2012 | 05:56 AM
You should also be able to narrow it down by unplugging fuses one at a time, first under the hood, then down stream under the dash. That will limit how much wiring you have to check. Also, unplug the hood alarm switch, so truck won't wake up and think it is under attack. Pix of fun with Debby storm?
Could be water in the trailer harness plug, (inside and below tail light on hinge side of rear cargo door, can puddle inside and not be seen) etc., or any of many other spots. Truck is gonna smell funky when mold starts to grow, you'll end up with all the carpets out to bake in the sun, etc. If they got wet.
Old Jun 28, 2012 | 08:56 AM
nadylime's Avatar
Thanks guy - Once everything dried out the lights went away & all is well.
I have someone coming to shampoo the carpets today
Old Jun 28, 2012 | 10:25 AM
drowssap's Avatar
You should really be concentrating on get the water that is in the pad and under the rug there are all kinds of nooks and cranies that water can hide in.
Shampooing the carpet is just going to get the surface, if possible you should either remove the carpet and let the floors dry a few days or put a dehumidified in it a couple of nights.
Old Jun 29, 2012 | 08:35 AM
nadylime's Avatar
How difficult is it to remove & re-install the carpets? Anyone done it? Any instructions on here?
Thanks guys.
Old Jun 29, 2012 | 09:17 AM
drowssap's Avatar
remove the seats/console, kick panels and rocker molding and they should lift out.
A couple of bolts and a lot of phillips screws, it will give you a chance to see if there is water sitting under your tranny ecu, most likely there is.
Old Jun 29, 2012 | 10:11 AM
oilspotLR's Avatar
Its not really that bad. Removing the center console is a must. (going solely on doing this in a DI)
roverparty
Jun 23, 2015 03:44 PM
ebg18t
Aug 30, 2012 07:08 PM
primey
Oct 5, 2011 10:06 PM
HelenaRover
Feb 16, 2011 07:48 PM
Street Wolf
Feb 8, 2009 09:04 PM
