Fuse box wire lugs
Old Sep 11, 2019 | 11:02 PM
CameraDan's Avatar
Default Fuse box wire lugs
Hey everyone! Looking for assistance tracking down a particular part:
I'm getting all the pieces together for a wire replacement, as I'm starting to have issues with corrosion on my positive battery lead. I'm going to replace all four of the big cables while I'm at it.
+ Battery to starter
+ Battery to fuse box
+ Fuse box to alternator
- Battery to chassis ground
The thing I'm having trouble with is the lugs on the fuse box/PDC end of two cables. Flat, 90° flag style lugs. Does anyone know of a source for these? I've tried searching this forum and others for info about this lug, too no avail.
Is there a suitable alternative solution that people implement? Do I need to to pry off the old one and try to reuse it? I could just modify the fuse box to accept a more standard straight lug? Or can the fuse box be bypassed with an in-line fuse for the alternator? Or will I have to fabricate a new lug?
Old Sep 12, 2019 | 03:31 AM
JUKE179r's Avatar
I wouldn't reuse the terminals.
The size of the terminals will depend on what gauge/size of cable you plan on using... 8AWG (thick cable) to 0AWG (thickest cable)
Soon, I plan on doing the "Big 5" cable swap:
ANCOR Marine grade cable tinned copper strands Type 3 or TEMCo welding cable
1. 0AWG cable from battery + to alternator + (through fuse box connected to 150A fuse link)
2. 0AWG from battery + to starter +
3. 0AWG from battery - to alternator mount
4. 0AWG from battery - to chassis
5. 0AWG from chassis to engine
*6. 10AWG from firewall to coil pack mount (replace braided ground)
Old Sep 12, 2019 | 11:52 AM
CameraDan's Avatar
I'm hoping to do mine in 2/0, but I got some 1/0 cable as well, just in case. I've got standard lugs for every other connection
But I just can't find any info on the weird shaped lugs for the fuse box. I'm willing to look at another cable gauge if it helps find the lug that fits.
JUKE179r, do you have additional cables on your car, or am I missing something? I only see one negative cable, that runs from the battery to the chassis and engine ground. Do you have an additional negative cable that runs from your battery to the alternator?
I am likely going to make my negative battery cable in two pieces, to replace that mid-cable ground lug. And the coil pack ground is a good idea! I'll do that soon, when I replace my coil packs and plug wires.
smoothb479
Dec 16, 2019 11:38 AM
Theodore L
Mar 20, 2017 04:20 PM
Germanwerks
Aug 27, 2015 10:16 PM
pinkytoe69
Mar 6, 2013 06:55 AM
Gerard
Jun 28, 2011 03:47 PM
