gap for Bosch Plus 4
Old 07-15-2008, 03:35 PM
2000 Disco 2 SD7's Avatar
Default gap for Bosch Plus 4
This could be a dumb question BUT just got home with new set of Plus 4 plugs and happened to notice printed on the box the words "never needs gapping". Really?
Now this is the first time I have ever used these plugs so that claim made me stop to ask someone here who has used these plugs before - you do gap these, right? My spec calls for .038 to .042, and my plan was to go with .042.
Old 07-15-2008, 03:40 PM
brooksa's Avatar
Default RE: gap for Bosch Plus 4
I do not think that the Bosch Plat 4's need to be gapped, but see if other people will confirm.
Old 07-15-2008, 03:45 PM
okdiscoguy's Avatar
should be pre-gapped. Don't touch them...
Old 07-15-2008, 03:47 PM
ORIGINAL: brooksa
Well.....just checking them as they come out of the box, the gaps range from .010 to .025, so some uniformity must occur before installation (in my simple mind anyway)
Old 07-15-2008, 04:01 PM
Check and see if the electrode is incased in ceramic, if it is that means that it doesnt wear down and it comes pre-gaped. And with a multi grounded plug plug you cannot really gap them yourself anyway.
Old 07-15-2008, 04:04 PM
ORIGINAL: Spike555
It is ceramic and ifI can check the gap, you can gap them.
Old 07-15-2008, 04:41 PM
[sm=guilty.gif]WARNING TO ALL! When using a product for the first time, read all directions! Further, when in doubt - ask before mutilating your new toys
Old 07-15-2008, 10:51 PM
Darover's Avatar
The spark will only jump the smallest gap in the 4 anyways and I think that 0.010 is pretty small to allow proper fuel burn.
Old 07-15-2008, 11:28 PM
Phototone's Avatar
ORIGINAL: Darover
The spark just "starts" the fuel burn. The fuel/air mixture then burns on its own. I don't think the small gap will influence the fuel burn as long as it "starts" the burn.
Old 07-16-2008, 05:00 PM
If you are going to mess with the gap then why buy a multi grounded plug?
Quick Reply: gap for Bosch Plus 4
