Gas Cap
Getting the P0441 about once a week lately... I will start with replacing the gas cap, does anyone have any experience with the $17 AllMakes one on Amazon?
https://smile.amazon.com/gp/product/...3360_424397570
Or is it necessary in this case to spend the $25 at L8 or the $50 at AB?
Also maybe this is related or not but have been hearing wheezy noises from behind the radio on start up. It goes away after a while, or if you turn off the climate control completely. AC has been working.
Thanks!
Thanks!
DiscoBuckeye (08-18-2019)
Dave03S (08-09-2019)
Heads up... The Allmakes cap from Amazon doesn't work. The screw hole for the tether is smaller than the stock screw. The cap fits but it has the wrong tether.
However as I already had the cap off, I took another stab at cleaning the thread on the fill pipe. Last time I cleaned it I think I may have just cleaned the top lip, this time with some scotch pad I scrubbed all around the thread and that seemed to dislodge some scale. Now that the cap is back on it seems to idle a little smoother... Won't know for sure until the code doesn't come back but something seems better.
![](https://cimg9.ibsrv.net/gimg/landroverforums.com-vbulletin/2000x1124/7a9fc8a0_ad20_4889_b63d_9ce9531522c0_87799afb6a38ecace01c1cfede188acf5f1c3fd5.png)
This gas cap is 5.99 at any Wal-Mart & 94-04 D1/D2 can have this gas cap. I’ve seen some 03-04’s with a different cap, but for sure the earlier ones have the same cap minus the lanyard & LR Logo.
All you have to do is pop the top off the old cap & the new cap. Then transfer the new threaded part (and all parts associated with it) onto the onto the old gas cap top (which allows you to keep the lanyard). Bingo you’ve replaced the old plastic thread piece & the valve with a new unit, and it only cost 5.99.
The following 2 users liked this post by Best4x4:
DiscoBuckeye (08-14-2019),
mollusc (08-14-2019)
