Gasket, Intake Manifold Valley
Old May 11, 2022 | 04:33 PM
Extinct's Avatar
You definitely have a plug passenger side valve cover breather tube. It is possible to remove the entire tube from the valve cover by gripping it with a pair of pliers and twisty until it comes out. You may want to remove the valve cover anyway so that you can replace the gaskets as they are probably old and hard and prone to leaking as well. If you have a no 3/04 truck be sure to remove the restrictor plate from the top of the breather tube before you reinstall it
Old May 13, 2022 | 11:41 AM
fma01709's Avatar
Thank you. Let me try that.
Old May 14, 2022 | 02:02 PM
fma01709's Avatar
Thank you for your advice. I did that, but now the nipple is a bit bent not 100% circle, and I cannot place the oil separator properly.
Do I need to place the oil separator is it needed? Is there a replacement for the nipple that connects to the valve cover?
Thank you
Old May 14, 2022 | 04:46 PM
mollusc's Avatar
Get rid of the oil separator and install the FV308 PCV instead. It won't matter if the tube is slightly out of round because it will just be the hose connecting to it.
Old May 14, 2022 | 07:16 PM
fma01709's Avatar
Thank you for the reply. I will order the FV308 PCV. Sorry, which side will go to the crankcase? a picture will be helpful if you have one.
Again, thank you.
Old May 14, 2022 | 07:23 PM
andino's Avatar
Here's the guide written by Best4x4: https://landroverforums.com/forum/di...install-92942/
Old May 14, 2022 | 08:11 PM
fma01709's Avatar
Sorry: But do I install FV308 for this as well. That is my question: I removed this part and does not fit anymore. Please see picture below thank you
Old May 14, 2022 | 08:30 PM
Extinct's Avatar
You need to cut that restrictor disc out of the top of that tube. Use a small copper tubing cutter do the job. About 1/4 inch down from the separation line between the disk and the tube
Old May 14, 2022 | 08:32 PM
fma01709's Avatar
Thanks
Old May 15, 2022 | 06:01 AM
mollusc's Avatar
And no, you don't install anything in there once you cut away the restrictor.
