Gasket job done when do I change the oil?
Old Sep 2, 2009 | 10:43 AM
IDAHODISCO's Avatar
Default Gasket job done when do I change the oil?
So the head gasket job is done When do I change the oil again?
So I have only slow drived arround the block with the fresh cheep oil and old hp-3001 oil filter now how long do I need to drive or run it before new filter and good oil change??
Thanks
Old Sep 2, 2009 | 12:14 PM
98roverguy's Avatar
I would've just changed the oil with good oil and filter at the time of the head job. Why keep an old dirty filter full of old oil and introduce that to a nice new set of heads. Did someone advise to wait or something? If it was me I would've already done it.
Old Sep 2, 2009 | 10:49 PM
LuvToDisco's Avatar
Should have flushed your engine after the job was done to get rid of any stray dirt and/or gasket material before adding fresh oil and filter.
Old Sep 2, 2009 | 11:37 PM
98roverguy's Avatar
That's overkill and not at all necessary.
Old Sep 3, 2009 | 04:12 AM
lipadj46's Avatar
After I did my head gaskets I flushed my coolant and refilled the PAS fluid. I ran the truck for about 10 minutes with the oil that was in there (2 week old mobil 1 unfortunately) and bled the power steering lines (and let the PB blaster and WD 40 burn off the exhaust manifold and engine). Then I changed the oil and filter to Autozone dino oil and a Fram filter ($25 total) and drove for about 100 miles and then did an oil change to my regular oil and filter.
Probably overkill but after spending 3 days doing that job I wanted to do it correctly.
Old Sep 3, 2009 | 06:29 AM
LuvToDisco's Avatar
Your entitled to your opinion. That old gasket material gets everywhere so I would flush the block out before bolting everything back together and adding fresh oil and filter etc. I'm not talking about doing an ATF flush.
Old Sep 3, 2009 | 07:46 AM
Thanks
Not sure why you are slow driving it and why you haven't done a proper oil change but do it Yesterday, why are you waiting.
Old Sep 3, 2009 | 10:46 AM
98roverguy's Avatar
Ok I thought you meant an ATF flush!
Old Sep 3, 2009 | 10:50 AM
IDAHODISCO's Avatar
I DID!
After I got her all back to gether I drained the oil and put cheep oil in 5 qrts I left my old hp- 3001 old oil filter in and have now driven 22 miles when should I change that oil??? With my Moble one oil and hp-3001 oil filter??
I also did the coolant flush!
Old Sep 3, 2009 | 11:39 AM
98roverguy's Avatar
I DID!
Your making this way too complicated. Mike is telling you to change your oil and filter with the mobil 1 oil and hp-3001 filter. Why are you waiting?
