Gasket Leak?
Old Mar 28, 2008 | 02:57 PM
modem7890's Avatar
Default Gasket Leak?
Last week I did a seafoam induction cleaning. After waiting the 10 to 15 minutes, I started the truck up. It smoked like I expected. However, a lot of smoke came out the downpipe/manifold gasket on the passenger side. While it wasrunning and smoking, I checked the rest of the exhaust system and found no other leaks, no smoke coming out of the downpipe/manifold onthe driver's side. I have been complaining about odd exhust sounds on this forum for some time (when I floor it to get on a highway I get this strange vibration sound from the exhaust). Also I see a little black soot on the heat shield between the downpipe and the engine block.
With that said, I took it to a local Midas shop today. They called me and said there is no leak and I just got back from picking it up. They didn't charge me, which was good, but even after I told them what I saw when I did the seafoam treatment they still said there was no leak. They said they blocked the tailpipe and found no leaks anywhere.
I ammissing something or doesn'tsmoke coming out of the gasket mean there's a leak.
Old Mar 28, 2008 | 03:01 PM
okdiscoguy's Avatar
Default RE: Gasket Leak?
Those are prone to cracking at the welds on the manifold, also the studs loosening. I have a problem with the studs right now, and with seafoam, it runs right out. I would replace the gasket there and when you are tightening back, make sure the studs are holding tight.
Old Mar 28, 2008 | 03:14 PM
modem7890's Avatar
Thanks Okdiscoguy.
The same thing happened when I seafoamed it, seafoam began leaking out of the gasket ( I didn't mention that in the post. Afraid I would get chastised for putting too much in too quickly). I told Midas that the liquid came out the gasket, but that didn't change their minds. I don't know, maybe it was aFriday afternoon and they just wanted to go home.
mike111
Jun 2, 2014 08:58 AM
Phatrowles
Jan 9, 2014 10:36 AM
JRover83
Sep 29, 2012 07:34 PM
jpmiller
Sep 26, 2012 06:32 AM
rgrizzard
Mar 6, 2008 10:16 AM
