Gaskets
Old Sep 14, 2007 | 10:24 AM
bigugly82's Avatar
Default Gaskets
Question:
Has/Does anyone use gasket sealer when they do a gasket job? I'll be going my intake manifold and was wonder if I should.
thanks
Old Sep 14, 2007 | 05:55 PM
geotrash's Avatar
Default RE: Gaskets
I never use sealants on gaskets unless the gasket manufacturer includes it or specifically calls for it. Gaskets are usually engineered to be installed dry and in some cases sealant can actually be detrimental, by weakinging the integriry of the gasket material or making it more likely that the gasket will walk as the bolts are tightened.
Quick story to illustrate. I used to have a 1982 Toyota Celica with the 22R engine that developed a leak in the exhaust manifold gasket. I replaced the gasket with good quality gaskets 3 times in 10,000 milesbefore an old codger at the auto parts store told me to quit using Permatexupon install. Iinstalledit the next time without Permatexand it held another 130,000 miles until I sold the car.
Cheers,
Dave
Old Sep 14, 2007 | 07:33 PM
dirtyduk's Avatar
Default RE: Gaskets
Doing an intake gasket I use two sealers
1) right stuff,(a permatex product) put a thin amount at the end seals where the head meats the block,but first make sure its all clean, install wet,dont let it sit or skin.
2) hylomar ,(wurth dp300)I put a veary thin coating at the coolant crossover ports, head and manifold
no other sealer and follow the torque specs. and dont over tighten the end clamps !
Have fun !
Old Sep 14, 2007 | 07:57 PM
okdiscoguy's Avatar
Default RE: Gaskets
I would only use it if it is called for, or if the surface you are sealing has a lot of nicks in it. I was trying to replace a blower motor in my old Chevy pickup, and someone had used sealant on the housing. I now have a 5" scar across my forearm and I have seenthe ligaments in my left hand.
If you use it, use it sparingly and evenly.
Old Sep 14, 2007 | 08:44 PM
Default RE: Gaskets
The main thing with doing an intake manifold is the replace the large gasket where the 8 tubes go from the top to the bottom of the manifold, Rover parts on.
RROJ
Mar 26, 2011 02:37 PM
drhunter
Mar 21, 2007 07:21 PM
rangerrick
Jan 25, 2007 05:10 PM
Steve O
Aug 25, 2006 04:26 PM
edthediscoman
Oct 5, 2005 01:58 PM
