Gasoline smell; where is better to start inspecting ?
I would look for leaks at the fuel line at the back of the manifold. Should be much stronger smell if you open the hood and sniff around by the ignition coils. If that is it, it is a potential fire hazard if you get a spark plug wire insulation issue that causes a spark to the firewall (common).
Probably leaking at the fuel line, but they had to disconnect it to get the intake off and then reseated it when the gasket was done.
